Hi,
I’m experiencing an issue with the Temporal Antialiasing Node. Im using 0.9.23.103 with a PLE license. I’m using the 03_CHAPTER_Particle_Systems file from the Intermediate course and seeing this on layers 3 and 4, Particle physics start and finish
When the node is connected to the root the scene is slightly blurry as I would expect with no jitter.
When the node is disconnected or disabled the scene is sharper but there is no jitter. https://vimeo.com/427536196
When the node is connected and the active property is set to 0 the scene is sharp but experiences jitter. https://vimeo.com/427536157
Am I right in expecting the disconnected and active set to 0 to have the same effect?
