Hey
Was wondering, is the Anti-aliasing full-frame always turn on when exporting out video, or do I need to turn it on beforehand?
Thanks
Hey
Thanks
Assuming your building a raytraced scene, you need to enable it on the RT Refinement node, and enable “Use Scene Refinement / AA Settings” on export.
Thanks, Ryan, so what if I’m not ray tracing and I put on full-frame from the drop-down menu view?
will this only be on in export if I tick it in the view drop_down menu?
Ah, that property I believe doesn’t function, and is on the chopping block for the next release. It used to run a more intensive AA method that we now have better alternatives for - I’d ignore that button for now.
