Hi ! I have a training builder and when I export here what happens! It stops after 2 frames…!
Edit : it works when I choose avi, but the problem appears if I choose mp4 ! image|668x500
Hey Romain!
If you are still having this problem, could you send us the project at support@notch.one
many thanks
Perhaps this is related to the issue over in this thread?
Hello ! Unfortunatly no… I’ve tried again on my new computer on the project and it doesn’t work… Can I send you the file ? I can export it without raytracing. And is it normal that it should take around 20 hours with raytracing, for 1 min of video ? I have a NUC9 with a rtx 2080TI from msi
but it works if I uncheck “use scene refinement”Hi Romain,
send us the dfx file on here or at support@notch.one and Ill take a look at it for you
many thanks
Harrison
