Notch stops rendering after a frame
I have been experiencing an issue with Notch. When i try to export video from a particles setup, Notch renders fine for 900 frames and then it starts rendering black(empty). I tested this with multiple scenes and the same thing happens.
I am using Rtx 2080 graphics card. Why do you think this problem is happening?
Thank you
Piril
