Seeking Help: Render Window Stuttering Issue
Hello everyone,
I recently started using NOTCH for creating real-time IMAG VFX, but I’ve noticed that the output in the Render Window stutters briefly at regular intervals. Could this be due to system settings or insufficient hardware resources?
Project Details:
  • Resolution: 3840 x 1080
  • CPU: 12th Gen Intel® Core™ i7-12700H @ 2.70 GHz
  • RAM: 32 GB
  • GPU: NVIDIA RTX 4090
Any advice or insights would be greatly appreciated!
I would definitely recommend not using the builder for live. It is warmly recommended to compile an .exe or notch block. You will gain a lot of extra fps.
What Soren said. There’s a good thread here with a lot of info on that. https://forum.notch.one/t/real-time-show-efficiency-best-practices/2185/6
