Hi,
I’m running some video into notch to add particle effects over it and every so often notch will pause the video for one frame then carry on playing. It’s not the first time i’ve noticed it and others i’ve spoken to have also complain of this. I’ve turned off auto save just incase this was the issue but it doesn’t help.
Has anyone else encountered this at all and is there a fix. I’ve also had it on other NOTCH projects.
