Hi
I finally got my Pro and Playback licenses and I am running into problems getting a Notch block to work with Green Hippo. I have a Boreal+ running v4.5.5 and I am using the latest version of Notch.
When I load a Notch Block downloaded from the Notch website it loads and runs as expected. If try to load a Notch Block that I have exported if hangs the engine. This happens with blocks made from the the sample Notch files and even a blank Notch file.
Is there something that I need to do on the Boreal+ to install Notch? The dongle is plugged in and the code meter web interface shows the license.
