Large scale projection setup
Hello everyone … i am trying to understand how we can use notch on large scale projection that require multiple pc ? any guide ?
If using D3 check - https://help.disguise.one/en/Content/Configuring/Networking/d3-net-overview.html
If using touchdesigner check - https://derivative.ca/UserGuide/Syncing_Multiple_Computers
https://derivative.ca/UserGuide/Hardware_Frame_Lock
understand … but the particle of notch cant be sync also right ?
I think you would want to cache your particle simulation if you were splitting it across multiple machines.
