Hi.
When dragging a mixamo .fbx animation into the node window from the resources window in builder trial version it will only show up as a 3D object not a 3D scene. Is that a limitation of the trial version or am I missing something?
Cheers
Hi.
Cheers
Hi Jack, is it your original model or a default model from Mixamo?
It’s a default model. Imported as a scene which allows animation but there’s no surface alpha for cloning. Thanks for the quick reply. Any way of getting surface alpha?
could you send the model over in support, and I will take a look.
support@notch.one
