I cant import AUDIO to notch ? :o
i have problems importing wave files and mp3 files to notch, i get 0 channels and a red file when i import, i can import everything else files is all good, but audio is not working :((
the audio files i want to use, work fine when i open them in other software.
Check if your file has special characters in it - Notch really doesn’t like that
Are you using a Learning, Base or Pro license?
