Can anyone confirm that Notch has difficulties importing longer wav files in the resource browser? As soon as I try to import a wav longer than plm 15 minutes Notch stops working.
Perhaps a bug? Just thought it good to mention. If anyone has the same issue let me know. Could be that it is due to conversion from aiff to waqv but all my shorter tracks which were converted the same way work fine.
Hi Jane,
Can’t repro your crash. Tried with 21 min wave file. This probably has to do with your file converter. Have you tried using Format Factory? Seems to work fine for me. You can find it here: http://www.pcfreetime.com/formatfactory/index.php?language=en.
-Andy
