I am creating a scene where a person appears out of the smoke.
I used the Field system, but the top of the smoke bounces around.
I would like to know how to make the smoke rise without bouncing.
Thank you in advance for your help.
Hi Yumi, what size is your bounding box? if you increas the size of your fields and bounding box does the top of the smoke continue to move upwards?
Thanks for the reply, Ctrld Chaos.
And sorry for the delay.
I was able to get better by adjusting the size of the BoundingBox and the size and position of the Field, as you suggested.
Thank you so much for letting me know!
Hi, Ctrld Chaos.Thank you for sharing this information!
