Hey
Is there a way to make custom shapes for the bounding box?
Thanks
Hey
Thanks
It sort of depends what you’re trying to do, but in most cases the answer is no.
The Bounding Box in a Field for example, sets in the min / max range on each axis for the field effect, so you can’t add a custom shape for this. You would instead use a custom mesh to collide and limit the movement of the smoke within its shape.
