chunky obj issue
Hello,
In an attempt to use the chunk effector deformer. The obj exported from C4D does not transfer to Notch properly. Any idea why the pieces of geometry do not look the same as in C4D. I’ve attached reference images.
-Az
Try to triangulate on export or before you export.
Cheers,
Chris
Thanks for the reply Chris. Still get the same results when the object is triangulated.
