Hi, Im trying to creat voronnoi effect(like in c4d), the question is how to creat two materials in one 3d object to outside and inner polygons?Thanks in advanced!
Hi Anius,
The best way is to import directly the object already fractured with C4D.
But in C4D you need to “connect object” if you want to use chunks deformer.
The mesh in C4D looks like that (with 2 materials):
And in notch when you inport the C4D mesh you’ll have both materials.
regards,
Adrien.
Tks Ardrien, I used FBX to fix this problem
