C4d / FBX Camera Issues
Does anyone know how to use an imported camera from an fbx / c4d scene. For the life of me I cant figure it out. I can import it fine, but for some reason I cant view the scene through that imported camera. I feel like I’m missing something pretty obvious. The node is connected to the root too.
Thanks!
Emmett
Have you enabled use cameras in the scene root? If you could upload an example fbx I’d be happy to take a look.
o wow, that worked! Super simple, thank you so much.
Hi Ryan, seems like I’m still running into issues. I have a 4 camera rig that just isn’t importing properly into Notch. It was handed to me as an alembic file. When I import to notch I see all the nodes, check the use cameras on the root, but I cant seem to look through any of the cameras in the viewport. I’m thinking its a scale issue, but not sure.
Trying to upload it but its saying it doesn’t support the file type / new user cant upload?
Hi Emmett,
If you are still having problems with your project, please contact our support team directly and include your dfx, C4D & ABC files.
We’ll be happy to take a look and help you out.
Kind regards
Will
