Keyframes in a Morph Controller are not saved in Notch 0.9.23.103, after re-opening a scene they are gone…
Hi,
It doesn’t actually save the keys. Looks like a bug.
I’ve informed the development team.
But you can use an “envelope modifier” and animate “Value” with keys. it’s working fine. :
Regards
Adrien
Thanks, that’s a good idea. I was just wondering after re-opening the scene and nothing happened…
