I’m using PLE Builder now.
I want to edit Notch Blocks that pre-installed on disguis, especialy “snow”.
I want to know how I could edit them(.dfxdll).
Require using Base or Professional Builder license?
Or I can’t edit any compiled blocks?
Then can I get source project files of them?
Hey Isaac,
Unfortunately we can’t hand out the source files to those projects, and compiled blocks cannot be converted to notch projects.
I will say those blocks are fairly simple though, so you should have no problem remaking them. The snow effect for example is simply particles falling in front of a camera with a few affectors, a snowflake texture on a point renderer, and a little distance shading to make the particles fade away at distance more.
Hopefully that helps point you in the right direction.
