Viewport render
Hi!
Is there a way to render what’s on the viewport without entering into the “Export Video” menu inside the “File” tab? When I do this the animation starts again and the already floating particles dissapear and start from zero. I want to render the actual status of the viewport without starting again or entering a “preroll time”.
Thanks!
No, you’ll need to cache the particle system otherwise the particles are reset on rendering a video.
