Synchronize multiple timelines
I`d need to synchronize the timelines of multiple notch patchs. Is it possible to exchange timecode between them?
What media server are you using? Presumably this is down to the application which loads your Notch Blocks. As far as the content, so long as all the nodes which contain the option between ‘Locked To Timcode’ and ‘Running/Loopable’ are set to the former, they’ll respect the timeline…
I was trying to synchronize Notch applications without using media server. I found out we can send OSC to control the timeline when using Notch builds. So I use a third party software to control the timelines of the machines together.
Hello Julien
Do you mind sharing with me this method? How is it achieved? Thanks a lot
Just as an aside; syncronizing timelines is exactly why you’d use a media server - that’s what they are built for. If you only want to do it in software, use something like TouchDesigner which is great for these types of installs.
