Hey
Just made a substance material following the guide in notch manual?
but I get a red texture?
Had the same prob with painter and which I fixed using Targa
But here i I’m not sure tried RBG without alpha?
Thanks
Hey
Thanks
Difficult to say without seeing the material or a nodegraph - at a guess, the material might be single channel and so notch just uses it in the R channel - if its an image it doesn’t make a difference for e.g roughness, metallicness, etc, if its a substance material node then i’d be curious in seeing what it is.
Sure, should I send it via the support email?
Can’t send it over here the file dos not work it says
Yeh go for support@notch.one, and explain what the issue is etc. One of the team (or myself of course) can take a look.
