Text to Render to Texture (Is it possible?)
Hi,
I’m just getting started with Notch, and I’ve had a root through everything here and online to try and find if there’s a solution to the problem I’m facing.
Is it possible to route a text node so that it is rendered as a material? (for use on 3d primitives?)
I’ve attempted this with the render to texture node and not had any luck.
One work around was to clone the text around the object, but wasn’t exactly what I was looking for.
Cheers
