Hey there…
I’m actually getting an error message while I’m trying to upload a sustance material downloaded directly from the sustance adobe site.
EDIT:::
I’m getting same issue trying with .exr files… ![]()
Does someone else get some issue?
Hey there…
EDIT:::
Could you send us the material or the exr?
Could you tell me how I do? actually the sytem just permit upload image files…
It may be easier for you to send this to our support team at support@notch.one ![]()
Hi guys, I’m having the same problem here, any solution?! I’ve already reinstalled the notch and drivers… still no solution…
Thanks
Hi, sorry you’re having issues with this. Please could you send the substance file that you’re having issues with to support@notch.one please?
