Issue about the import from c4d project
hello ~
, i already locate the texture files for whole set model. and drop in to notch… i found there’s only load up normal texture. files. other texture is dissapear ,😭 i am sure its locate the right file b4 load in to notch ~
anyone can help me out of this ~~. its so painful to manual apply for each model 😔 thank you so much !!🙏
I’ve had exactly the same issues and maybe it’s coincidental but it was also with KitBash 3D assets, I just had to get it working so took the manual route - when applying the textures directly into the material node instead of dropping them into the graph and connecting them, it is at least a little quicker
