Hi, I know notch has spout support has anyone ever tried to use it with spout unreal engine Plugin? I am currently trying to get a Kinect Feed from notch to unreal via spout but cant get it to work! I enabled spout in Project settings, where can I See the spout sender Name so I can reference it in unreal engine? I would appreciate any help or insight
you should be able to test your Spout connection and see the name with the ‘SpoutSender.exe’ and ‘SpoutReceiver.exe’ programs downloadable from the developers website (they’re usually in the ‘Demo’ folder).
For Notch I’m pretty sure the sender name defaults to ‘Notch Builder Spout Sender’
