Notch Builder:
0.9.23.209
Issue:
Cannot link output value modifier to Any Position Delta of the Spline Deformer.
Priority:
Very low
Reproduction steps :
- Add a Spline Deformer node
- Add, for example, a Math Modifier
- Try to link the output of the Math Modifier to Any Position Delta X/Y/Z of the Spline Deformer node
Expected result:
A link
Actual result:
Link is invalidated
Log
No Warning / Error Logging
I guess it’s because of the Delta nature of the parameters, but there’s no ergonomic behaviour to tell the difference.
Mind that the Key frames behaviour in Curve Editor works as expected.
No workaround needed.
