Hello,
Is there a way to use a random affector to generate random camera shake/motion? Some sort of Position Noise?
-Az
Hello,
-Az
Hey There,
Your best bet for this would be using a Math Modifier set to Perlin Noise connected to the X/Y positions of the camera. I’ve made attached a slightly more complex example of this, so that the movement changes are all in local space, and so it’s a little more customizable.
Hello Ryan,
Thank you kindly for the response. I figured there was a simple way to achieve camera motion. Much appreciated.
-Az
