Rigged bodies from Mixamo
I’m trying out some different 3d rigged characters by Adobe Mixamo.
Some are working fine in connection with a Kinect, but some are acting strange.
Are there differences between the characters?
Or is there an another way to get them working?
Hey Florian,
It is likely that the number of bones is what makes a difference, Kinect does not use fingers, so if your model comes in with finger bones it may throw off the Kinect skeleton reader. I made a short demo of how to set Mixamo model for Kinect2, check it out, hopefully it will help you here - https://www.behance.net/gallery/96492975/Kinect2-to-Notch-via-Mixamo
Best,
Armin
Hey Armin,
thanks for your reply! Your tutorial is great and helped a lot!
