I’m useing Builder PLE 0.9.20.
I can’t find these nodes below, but on manual written.
x Kinect Mesh Clone Modifier
x Kinect Mesh Collapse Modifier
x Kinect Mesh Extrude Modifier
x Kinect Mesh Project Image Modifier
x Kinect Mesh Smooth Modifier
x Kinect Mesh Emitter
They had replaced with other nodes?
or I failed installation?
Anyway, I want some useful kinect sample projects…
We are getting rid of those nodes as they aren’t really useful anymore, and you can mostly do what they did better with other nodes now. I had though I had hidden those nodes from the manual, but apparently I need to be more thorough…
I’ve got a simple Kinect example attached below. Hopefully that helps point you in the right direction.
I tryed “KinectExample.dfx” with Kinect2.
I thought something wrong with arms bone of this Human model.
This model always raise his hands up like attached image.
Other parts are good.
There could be a number of reasons for this relating to noisey outputs from the Kinect sensor, but try toggling Rotation Follows Direction in the Kinect Skeleton. This can be useful for some skeletons but isn’t always, I may have left it on accidentally.
Hi ryan,
Really need the kinect example but i cant find the attached.If u got time to make some tuts about the kinect, I will be really appreciate!!! Thanks in advanced!
Hi Ryan,
Thank u so much!!It really helps me a lot.But there is other question, when u import the fbx file it show as a imported 3d scene, so it cant be a mesh emitter to the particle system right?I saw the video u guys showing in frankfurt, there is a dancer in the monitor,and the particles can emitter from the mesh, so I wonder how to do that.Really appreciated!!!
Click the triangle below the Imported 3D node, then you’ll see everything within the fbx scene. output from the mesh to the mesh emitter, and your good to go.
Alternatively, you can still use an object node, and select the fbx scene from the object dropdown menu.
Hi, I would also like to take a look at the working example of the skeleton. I tried to use the standard skeleton from 3ds Max, I only activated a pair of bones. I guess that the matter is in the name of the bones, I would like to know how they are called from you. Please attach your sample, because there is very little information, the description in the manual is also very superficial. Thank you in advance
