Reset orbit camera
Hi Notch,
Is there a way to reset the orbit camera when you get lost navigating?
Thank you.
C
Hi Cadie,
Can I assume you mean the free camera view, and not the actual Orbit Camera? If so; just select something and hit Alt-F.
If you’re using an Orbit Camera Node, simply reset its properties (hit the “recycle”-icon in the properties panel after having selected the Orbit Camera Node in the node graph).
Alt-F
Thank you, very quick reply!
C
