Resetting the view screen to a default view
Hi, I have created a project with a sound resource but as I completed the layout the timeline disappeared and now I cannot see where the audio file waveform is.
Is there a simple way to reset the view without all the other windows overlapping and making it difficult to edit.
View>Restore Original Layout should do it. Its worth noting that when you enable the waveform view in the timeline, it will mess up your layout, but if you restore and then maximize the Notch window, everything will be as it should.
