Reset default layout
How you delete the preferences file so the program will start with a default layout?
The “restore original layout” menu item is not working.
Thanks
hi,
What’s wrong with your layout?
"restore original layout” has no effect at all?
Regards,
Adrien
I am having this issue. My node graph is not showing up and “restore layout” had no effect. A fresh install did not help either.
Sounds like you’re facing a bug. Can you send your logs from C:\Users\hackj\Documents\Notch\Logs to us via a support ticket?
Thanks for getting back to me. I couldn’t get the folder to attach so sorry for all the attachments.
Thanks again,
Steve
notch_log__2023-09-06__09-39-33.txt (68.9 KB)
notch_log__2023-09-06__09-32-16.txt (42.4 KB)
