Hi all
we are trying to achieve to get a post effect not applying to the whole image. Therefore we use a render layer and add the postFX (like Glow) only to the parts of the image we need. But as i can see, Render Layer has no Alpha channel or the objects that render to render layer are not visible to root node -> View Layer Alpha… does this mean reander Layer only produces RGB but not A. correct?
