Problem using Multiple Depth Camera / Kinect Meshes
I’m having an issue using more than on Depth Camera / Kinect Mesh Nodes. The first node I have works fine, but once I added in a second one, using the same depth and image source, it won’t generate a mesh. Any thoughts ?
Hey There,
Is it not possible to just use one Kinect Source node, and connect that to multiple pieces of geometry?
I suspect that both are fighting each other for the same data source.
