Two kinects V2 in one PC
Hello
Some recommendation to connect two kinects in the same computer ?¿
I tried to use two kinects V2 at the same computer.
My computer detects the two cameras connected in USB 3
but Notch detect only one camera.
I`m in Windows 11, could be a problem ?¿
Thanks for your feedback !
I’m also interested to know if notch accept multiple Kinect v2 devices, does someone know the answer ?
Notch only supports one Kinect v2 at a time, this is a driver limitation from Microsoft.
Hello Nizar
To conect 2 kinect at same PC you need to use iprecorder
instead to SDK from windows
https://www.ipisoft.com/download
Thanks Ip recorder you can turn on 2 kinect at same time.
Then, you need “somthing” between Notch and Iprecorder,
In my case I use Processing to get the image from the two kinects and send it to NOTCH like a SPOUT.
Thake in consideration NOTCH don´r support two SPOUT signal.
In my case was a dificult process that requires many test.
Here the final result
If you need ome help you can conect me directly
