NotchLC video goes to solid white after 20:09:03
My encoded video works for about the first 20 minutes and then turns solid white for the remainder of the frames. This does not happen in the source video I’m encoding. It’s only in the NotchLC encoded file. The behavior happens in both Premiere and Media Encoder.
Update on this.
After some troubleshooting and talking to support I’ve learned a few things.
The problem seems to be with Adobe’s reading of the file, not the actual video. The same file plays fine in other players. The problem is also not that it cuts to white, but that it cuts to the first frame after 20:09:03. I happened to first encounter this on a video that started on white.
So hopefully the NotchLC team can figure it out and release an update.
