Just installed the latest Notch Builder 0.9.23.098.
Freeze issues appeared when navigating in the viewport.
No issues with 0.9.22.
Tried uninstalling/installing several times, nothing seems to help.
Win 10 Pro
GPU 1 RTX2070 Super
GPU 2 RTX2060 Super
Tried on studio driver version - 441.66 and latest 442.19
All other drivers are up to date.
Hey There,
Are you using a pen tablet/display? We had found an issue with them recently, and the next patch release has a fix for these. This looks like the same issue.
Hello. Thank you for reply.
Yes, I’m using Wacom Intuos Pro tablet!
Is there any release date info?
Or can I download previous version from 9.23 updates? legacy 9.22 is missing some of the crucial elements for me.
Is there a fix for this? Currently dealing with this issue.
Same freeze issue sometime still exist with a Wacom :-/
Hey there,
Could you send this over to support@notch.one? We haven’t been able to repro this issue since it was solved, so if you could send a dfx and some repro steps would help us identify what’s going on.
