Hi all, I’m a Notch newbie who has been soaking up every tutorial that I can get my hands on. We are currently working on integrating Notch into Disguise to run XR events. My plan is to have a virtual environment running on the back plate and then some overlay content running on the front plate. We have this working as it should, but I’m a little lost on the next step which is the actual show flow.
Say we have a corporate presentation which needs to display different 3D models one after the other; a car animates on screen, then it disappears. This is replaced by a TV screen that has a live input on it. This goes away and something else comes up. What is the best way to have these animating on and off? Do you put these on separate layers and tick off ‘Layers as separate effects’? How then does the front plate work? Should everything be on the same layer?
Hopefully the question makes sense!
