Hey
When using substance material, what does Normal format mean/do?
Thanks
Hey
Thanks
This property exposed by substance materials to control switching between opengl and directX rendering - Notch only uses DirectX, so you should expose it / alter it as it will only break your normals. We’re actually hiding that option for the next release so it won’t cause confusion further.
thanks, Ryan, can’t wait for the upcoming Notch
