No Alpha export possible
Since the Indie version (Trial) is limited to MP4 export only, the Alpha channel can not be exported.
I understand, that you want to limit the export quality, but please look into implementing at least one stable solution for Alpha export, maybe as separate video layer or as NotchLC, which would help to spread the format.
Thank you very much.
