Does anyone have experience in bringing NDI sources into NOTCH? I am not quite sure how to list them in the NDI source node.
It appears NDI input doesn’t work with the image plane or any object other than the image 2d. Is there a way around this to render it as a flat image and send it to another node possibly?
Hey Evan,
Drop us a line to our support email (support@notch.one), and we’ll get you a newer build which has a lot of bug fixes along those lines.
