Hi there,
i’m going to build a dynamic stage with Notch for live streamings which consists of multipe video sources that are being captured via NDI.
To build a PoC i just simply added two NDI sources inside my project which are mapped onto two Image 2D nodes. In the project settings i also activated the NDI sender as i need to have one return feed. From a technical perspective this works.
But: When i view the NDI output from notch, the embedded NDI sources are looking blury. It also seems that there are frame drops. I’ve verified the quality of my network NDI streams via NDI Studio Monitor - there everything runs smoothly. It also seems that inside the notch viewport the quality is better. (better picture quality, but also frame drops).
Is there a way to optimize the NDI handling inside of Notch?
