Using the NDI outputs node on the same level causes the problem that the NDI sender names are all scramble when you want to recover the NDI into another software.
For example, when I try to get them with the NDI receiver in MadMapper the name doesn’t correspond to the notch NDI output source and the visuals are randomly named.
Another thing I noticed, when the NDI output node is deleted from the nodgraph the NDI list of sources is not updated, unless I refresh the NDI Source list in the Video IN/Camera/Kinect… panel.
I have encountered this issue many times when working in Notch Builder Pro.
Is it possible in the Video IN/Camera/Kinect… panel to disable the NDI Notch main sender and keep only the NDI output senders?
