Multiple Spout Input//Outpus
Are there plans to implement multiple Spout Input//Outputs ? One of the most useful features of Spout is being able to classify multiple outputs from various sources and receive them in a visual framework such as Notch or Touchdesigner. It’s built into the Spout SDK so I’m curious if you have thought about implementing this into Notch.
Hello Wooliii,
That is on Dev teams radar, it will be implemented in the future releases.
Best,
Armin
Hello Armin,
Is it supposed to be addressed?
I just tested with mutiple spout sources and changing the “Source Index” doesnt’t change my Spout source, while I can see all my sources in Madmapper for example.
Benjamin
Hi Benjamin,
This is still on our development list for a future version of Notch.
Regards,
Tom
