Multicamera_ arrangement
Hello guys,
I’ve got a little isue…
I want tio export a notch bloc of a scene I made with different point of view of camera…
To be exact 6 camera…
But when I plug le 6 cameras in the multi camera… I only get the possibility to have a 4 by 1 grid
So 4 camera in the first line et 2 in the second…
It give me a lot of lost pixel in the second line… So I need to export a bloc larger than I need …
Is there a way to do a 3 by 2 instead ?
Thanks you
Raphael
I would look into the “Select Child Node”. Plug the cameras into it and then change the value to change camera. Just make sure they are arranged in vertical order in your node grid to make it easier to know which camera you’re using
Hello torbjornfernstrom, thanks for the answer
But there a misunderstanding,
I want used them all in the same time, in the same block…
But I want to make a grid of 3 by 2 to save some pixel… right now I forced to to do a 4 by 2
Raph
