I’m trying to render two identical camera view in multi camera node with different post FX, but when I plug in the post FX, there is nothing change in the view?
What did I do wrong?
Hey Yu,
I’m afraid that’s not possible with the multi-camera. Post-FX is applied once the scene is rendered, so any Post-FX has to be applied to the scene or the Multi-Cam, not the individual camera inputs.
You would need to render both scenes individually, and similarly apply Post-FX to those scenes individually. You can do this with either the Render To Texture or Render layer - attached is an example of a setup with the Render To Texture.
Thanks for the reply!
