Hello,
I put a nodegraph in a bin for the purpose of transferring it to another Notch project.
However, once I load the bin in my other project, and link it to the root, many things are shifted and keyframes are acting strange. In short, is there a better way to transfer a nodegraph between projects? Or am I doing something wrong? Do things tend to scramble around when put in a bin and then imported?
Any advice is greatly appreciated.
Harry
Hi Harry,
We’re looking into this now.
In the mean time have you tried merging the projects.
File/merge projects.
Then copy paste the nodes into the project layer that you want them to be in.
Regards
Will
Hi Harry,
Can we get a copy of your bin please?
Also, what version of Notch are you using?
Regards,
Tom
Hi,
Thanks for the reply.
I’m using 9.23 with a learning license.
Sorry for the silly question, but where are bins stored by default again? I have only made one and I can’t seem to find it anymore.
Harry
Hi Harry : bins a re here:
C:\Users"username"\Documents\Notch\Notch Bins
Regards,
Adrien
