I am trying to make an infinity mirror -
while the reflection of a mirror works. It only does so showing the objects as if deferred rendering is turned off (silhouette objects)
Is there a way to fix this?
Hey There,
Which Reflection node are you using? if its just Mirror Reflections, that is limited to only one bounce (which looks like what you are seeing). Try a multibounce reflection node.
