Hello,
Recently I made a little breakdown of one of my R&Ds, one section of it is dedicated to connecting Leap Motion Sensor to Notch using OSC signal from Geco.
I figured it might come handy to some, so here is a link with a timestamp:
Hello,
Hello Armin,
thanks for your How-To and the tip for the Geco Software - this looks handy!
I tried Leap Motion SDK/Software 4.0 with Geco but it says no Controller connected even though in TouchDesigner it works fine.
I tried Leap Motion Legacy Software but then the Leap Motion isn’t recognized in windows 10.
Am I missing something obvious?
Windows Pro 1909
Thanks in advance.
Hello Raphael,
I had this issue too, but installing - LEAPDeveloperKit - 3.2.1 solved it, Geco is not actively developed these past years, that makes it a bit uncomfortable to use. Please let me know if - LEAPDeveloperKit - 3.2.1. resolves your problem.
Best,
Armin
I was having issues as well, but indeed Leap 3.2.1 + GECO 1.3.0 is working as expected on Windows 10 Pro 64-bit build 1909.
Ineed it solved the problem.
Thanks!
Thank you guys for the feedback, I have noted this in the video description too, for future reference.
