Groups and bins disconnect on layer duplication
Issue: When duplicating a layer, groups disconnect from their parent in the nodegraph.
Repro Steps:
* Connect group/bin to a parent node
* Duplicate layer
* Connection will be disconnected
Hey there,
That’s an interesting find, it looks like the issue is specifically when nodes are connected to the bins input/output connections - I didnt see it with parent connections.
That said, we’re looking closely at this workflow in the next release, so this kind of issue will be solved indirectly there.
